95 62 190 T
95 62 190 T
    KNIPEX(凯尼派克)
    Cutter, 190 mm, 7 mm, 64 °
95 62 190 T 数据手册
95 62 190 T Wire Rope Cutter with tether attachment point with tether attachment point ● ● ● ● ● ● ● With two crimping dies for end caps on Bowden cable sheaths and end ferrules for traction cables Comfortable work thanks to handy, slim design and internal opening spring Bolted joint for precise blade guidance, re-adjustable High leverage for reduced effort Cutting-edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Pliers with tether attachment point for mounting a fall protection Cuts all wire ropes without splaying, including those that are extremely strong Article No. 95 62 190 T EAN 4003773080206 Head burnished Handles with multi-component grips, with integrated tether attachment point for a tool tether Cutting capacity copper cable, multiple7,0 stranded (diameter) Ø mm Crimping of the end Crimping of the end ferrule onto the traction caps on the Bowden cable cable sheath Internal opening spring Cutting capacities wire 5,0 rope (diameter) Ø mm Cutting capacities medium hard wire (diameter) Ø mm 4,0 Cutting capacities piano wire (diameter) Ø mm 2,5 AWG 7 Length mm 190 Net weight g 345 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 62 190 T 价格&库存
很抱歉,暂时无法提供与“95 62 190 T”相匹配的价格&库存,您可以联系我们找货
