00 21 37 LE
00 21 37 LE
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 37 LE - TOOL CASE, PP, ROBUST45, 428X609X263MM
00 21 37 LE 数据手册
00 21 37 LE Tool Case "Robust45" with integrated rollers and telescopic handle empty ● ● ● ● ● ● ● ● ● ● ● ● Article No. 00 21 37 LE EAN 4003773082590 Dimension exterior (interior) width mm mm 609 (540) Dimension exterior (interior) height mm mm 263 (229) Dimension exterior (interior) depth mm mm 428 (364) Net weight g 10800 Fit to fly case, made from impact-resistant polypropylene Dustproof and watertight Air pressure compensation valve Temperatures ranging from - 30°C to + 80° C Padlock eyelets Document compartment; tool boards with 54 tool pockets and 94 straps Lockable base tray can be individually divided using aluminium separator system Ergonomic dual-component handle With two smooth castors With telescopic handle Volume: 45 l 35 kg maximum load technical change and errors excepted Con-Pearl® is a registered trade mark of friedola TECH GmbH KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 37 LE 价格&库存
很抱歉,暂时无法提供与“00 21 37 LE”相匹配的价格&库存,您可以联系我们找货
