12 11 180
12 11 180
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 10 ~ 20 AWG
12 11 180 数据手册
12 11 180 Insulation Stripper with adapted blades ● ● ● ● ● ● ● Article No. 12 11 180 EAN 4003773000792 Pliers black lacquered Handles with plastic grips Stripping capacities (diameter) Ø mm 0,5 / 1,2 / 1,6 / 2,0 Length mm 180 Net weight g 368 With replaceable blades for 4 or 6 different conductor cross-sections Leave wire undamaged thanks to precision-ground blade shapes, even multi-stranded conductors are stripped gently During stripping, the wire is held firmly by clamping jaws With length stop for constant stripping length during repetitive work A spring leads the stripper back to the starting position Pliers body: aluminium Blade: special tool steel, oil-hardened technical change and errors excepted Spare Parts Article No. EAN 12 19 180 4003773022145 1 pair of spare blades for 12 11 180 with adapted blades 12 19 180 04 4003773052876 Insulation support (4) for 12 11/21 .. 12 19 180 06 4003773052890 Guide plate (6) for 12 11/21 .. 12 19 180 07 4003773052906 Joining bar (7) for 12 11/21 .. 12 19 180 08 4003773052913 Bolt (8) for 12 11/21 .. 12 19 180 09 4003773052920 Screw (9) for 12 11/21 .. 12 19 180 10 4003773052937 Torsion spring (10) for 12 11/21 .. 12 19 180 11 4003773052944 Washer (11) for 12 11/21 .. 12 19 180 12 4003773052951 for 12 11/21 .. 12 19 180 13 4003773052968 Opening spring (13) for 12 11/21 .. 12 19 180 14 4003773052975 Joint screw (14) for 12 11/21 .. 12 19 180 15 4003773052982 Handle sleeve (15) for 12 11/21 .. 12 19 180 16 4003773052999 Intermediate stop lever (16) for 12 11/21 .. KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 12 19 180 17 4003773053002 Bolt for intermediate stop lever (17) for 12 11/21 .. 12 19 180 22 4003773053057 for 12 11/21 .. 12 19 180 23 4003773053064 Adjusting and fastening screws (20-21) for 12 11/21 .. KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
12 11 180 价格&库存
很抱歉,暂时无法提供与“12 11 180”相匹配的价格&库存,您可以联系我们找货
