12 12 11
12 12 11
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 10 ~ 15 AWG
12 12 11 数据手册
12 12 11 Precision Insulation Stripper with adapted blades ● ● ● ● ● ● ● ● Form-fit stripping also of difficult-to-remove insulating materials made of PTFE, silicone, Radox®, Kapton® and rubber; multi-layer too A second pair of blades holds the remaining insulation reliably in place Replaceable shaped blade adapted precisely to the respective conductor cross-section With length stop for constant stripping length during repetitive work Pliers body: steel Blade: special tool steel, oil-hardened For solar cables, specially adapted to multi-layered and RADOX® insulations With additional cable support for a better centring of multi-layer insulated conductors in the stripping profiles Precisely and reliably Two pairs of blades (1) cut the insulation to a complete extent. Then the blade pairs move apart, and thus the insulation is removed form-fit (2). The pliers open automatically after the stripping procedure. Principle of operation with adapted blades Properly and precise stripping with an annular cut through the complete insulation. This is particularly important with conductors, which must be stripped precisely. This works without any problem even with difficult insulating materials made of PTFE, Radox® and multilayer insulations. Article No. 12 12 11 EAN 4003773062998 Pliers burnished Handles with multi-component grips Stripping capacities in square millimetres mm² 1,5 / 2,5 / 4,0 / 6,0 AWG 15 - 10 Length mm 195 Net weight g 449 Precise cutting of the Positive stripping insulation to a complete thanks to precise shape extent of the blades technical change and errors excepted Spare Parts KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Article No. EAN 12 19 11 4003773063001 1 set of spare blades for 12 12 11 12 19 91 4003773079439 Set of springs for 12 12 xx with adapted blades Accessories Article No. EAN 12 19 90 4003773078982 Length stop for 12 12 xx with adapted blades KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
12 12 11
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离型集成电路,用于红外发射和接收。
3. 引脚分配:EL817有5个引脚,包括Vcc、Out、GND、Vo和LE。
4. 参数特性:工作电压为3-15V,工作电流为10mA,隔离电压为2.5kV。
5. 功能详解:EL817通过红外信号实现电信号的传输,具有抗干扰能力强、传输距离远等特点。
6. 应用信息:EL817广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:EL817采用DIP-5封装。
12 12 11 价格&库存
很抱歉,暂时无法提供与“12 12 11”相匹配的价格&库存,您可以联系我们找货
