48 31 J2
48 31 J2
    KNIPEX(凯尼派克)
    KNIPEX - 48 31 J2 - Plier, Circlip, 60 mm Jaw Opening Max, 180 mm, Grey Atramentised
48 31 J2 数据手册
Product information 48 31 J2 ● Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips ● With inserted tips for reliable work ● ● ● ● ● Precision Circlip Pliers For internal circlips in bore holes With overstretching limiter ● ● DIN 5256 C ● ● ● Bolted joint: precise, zero backlash operation of pliers Non-slip plastic coating on the handles With overexpansion guard (adjustable using end stop) Adjustment using hexagonal screw Ideal for series production as excessive expansion of rings is effectively prevented DIN 5256 C, straight tips With overstretching limiter for standardized assembly in accordance with DIN 472 The adjustable stop screw prevents the rings from overstretching Inserted tips: spring steel wire, drawn Pliers body: chrome vanadium electric steel, forged, oil-hardened General Article No. 48 31 J2 EAN 4003773073871 Pliers grey atramentized Handles with non-slip plastic coating weight 175 g Dimensions 180 x 86 x 38 mm Standard DIN 5256 C Technische Attribute Style 3 Size of bore Ø 19 – 60 mm Tips (diameter) Ø 1.8 mm Classification eCl@ss 5.1.4 21040301 ETIM 5.0 EC002228 ETIM 6.0 EC002228 proficl@ss 6.0 AAC470c002 UNSPSC 13.1 27112140 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 1
48 31 J2 价格&库存
很抱歉,暂时无法提供与“48 31 J2”相匹配的价格&库存,您可以联系我们找货
