74 01 140
74 01 140
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 5.50"(139.7mm)
74 01 140 数据手册
74 01 140 High Leverage Diagonal Cutter ● ● ● ● For very tough, continuous use High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction hardened (cutting edge hardness approx. 64 HRC), for all sorts of wire including piano wire Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 01 140 EAN 4003773039747 Pliers black atramentized Head polished Handles plastic coated Style 0 Cutting capacities medium hard wire (diameter) Ø mm 3,1 Cutting capacities hard 2,0 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 1,5 Length mm 140 Net weight g 131 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 01 140 价格&库存
很抱歉,暂时无法提供与“74 01 140”相匹配的价格&库存,您可以联系我们找货
