78 13 125 ESD
78 13 125 ESD
    KNIPEX(凯尼派克)
    n/a
78 13 125 ESD 数据手册
78 13 125 Electronic Super Knips® ● ● ● ● ● ● ● ● ● ● Article No. 78 13 125 EAN 4003773035398 Head polished Handles with multi-component grips Style 1 Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Ground, very sharp cutting edges without bevel Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life Precision shaped tips cut wires resting on a board from 0.2 mm dia. Joint with stainless steel rivet Extremely smooth movement for minimum operator fatigue With opening spring and opening limiter With lead catcher - no uncontrolled loss of cut wire ends Cutting edge hardness approx. 54 HRC INOX - tool steel Pliers Cutting capacities medium hard wire (diameter) Ø mm 1,0 Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,6 D mm 7,5 B mm 9,0 A mm 13,5 Length mm 125 Net weight g 57 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
78 13 125 ESD 价格&库存
很抱歉,暂时无法提供与“78 13 125 ESD”相匹配的价格&库存,您可以联系我们找货
