79 32 125 ESD
Precision Electronics Side Cutter ESD
Electrically discharging handles - dissipative
Precision pliers for ultra fine cutting work, e. g. in electronics and fine
mechanics
Very precisely ground and sharp cutting edges with very small bevels
for exact cutting on delicate electronic components; also available
without bevel for flush cutting
Cutting edges additionally induction hardened, cutting edge hardness
approx. 64 HRC
Approx. 20% lighter than conventional electronics pliers
Bolted joint with carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range
Smooth-running double spring for a gentle and even opening
Ergonomically optimised multi-component handles
Ball bearing chrome steel, forged, multi stage oil-hardened
Pointed head
The subtle difference
KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening
movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals.
ESD pliers (electrostatic discharge)
electrostatic energy is discharged through the handles in a gradual and controlled manner
which protects components endangered by electrostatic discharge
in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472
Article No.
79 32 125 ESD
EAN
4003773061557
Pliers
burnished
Head
polished
Handles
with multi-component
grips
Style
3
Cutting capacities
medium hard wire
(diameter) Ø mm
1,1
Cutting capacities hard
0,6
wire (diameter) Ø mm
Cutting capacities soft
0,2 - 1,5
B mm
10,5
D mm
6,5
A mm
11
Length mm
125
Net weight g
61
technical change and errors excepted
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
2
很抱歉,暂时无法提供与“79 32 125 ESD”相匹配的价格&库存,您可以联系我们找货
