98 24 01 SLS
98 24 01 SLS
    KNIPEX(凯尼派克)
    KNIPEX - 98 24 01 SLS - Phillips Screwdriver, #1 Tip, 80 mm Blade Length, 187 mm Overall Length, Plu...
98 24 01 SLS 数据手册
98 24 01 SLS (Slim) PlusMinus screwdriver Phillips® ● ● ● ● ● ● Article No. 98 24 01 SLS EAN 4003773081036 Tip burnished Handle insulating multicomponent handle, VDEtested Size PH1 Blade length mm 80 Handle length mm 107 Nominal size PH1 Length of noninsulated blade mm 15 Length mm 187 Net weight g 56 Driving tips for PlusMinus profile screws Use with electronics installation components, e.g. automatic circuit breakers Reduced blade isolation diameter for recessed spring and screw elements Ergonomically optimised dual component handle for fatigue reduced work and optimum transmission of force Handle design prevents rolling Chrome vanadium molybdenum steel technical change and errors excepted Phillips® is a registered trademark of Phillips Screw Company KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
98 24 01 SLS 价格&库存
很抱歉,暂时无法提供与“98 24 01 SLS”相匹配的价格&库存,您可以联系我们找货
