08 22 145
08 22 145
    KNIPEX(凯尼派克)
    组合 钳子 针嘴 有齿 5.75"(146.1mm)
08 22 145 数据手册
08 Needle-Nose Combination Pliers DIN ISO 5746 Small High Leverage Combination Pliers with pointed jaw. For all common installation and repair work. ● ● ● ● 08 21 145 ● ● ● ● ● handy use when working in confined areas thanks to slim head design and pointed jaws (anti-twist) Gripping surfaces with special convex contour on one side for secure gripping of flat parts milled groove in the gripping area permits small parts such as nails, pins and bolts to be held and pulled the reliable and diverse combination pliers when out and about easy cutting thanks to the high leverage joint with cutting edges for soft, medium-hard and hard wire long service life and stable tips forged from special high grade tool steel, manifold oilhardened 08 22 145 T: Pliers with tether attachment point for mounting a fall protection 08 22 145 08 22 145 T 08 25 145 08 26 145 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Article No. EAN 4003773- Pliers Head Handles 08 21 145 078951 black atramentized polished plastic coated 08 22 145 078968 black atramentized polished 08 22 145 T 080640 08 25 145 078975 08 26 145 079361 Ø mm Ø mm Ø mm mm² mm g 3,0 2,0 8,0 16,0 145 116 3,0 2,0 8,0 16,0 145 145 polished with multi-component grips 3,0 2,0 8,0 16,0 145 150 chrome plated with multi-component grips 3,0 2,0 8,0 16,0 145 145 chrome plated insulated with multicomponent grips, VDEtested 2,0 8,0 16,0 145 145 handles with multicomponent grips 3,0 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
08 22 145 价格&库存
很抱歉,暂时无法提供与“08 22 145”相匹配的价格&库存,您可以联系我们找货
