12 40 200
12 40 200
    KNIPEX(凯尼派克)
    工具 单层剥除器,自调 用于 8 ~ 32 AWG
12 40 200 数据手册
12 40 200 Self-Adjusting Insulation Stripper ● ● ● ● ● ● ● ● ● ● For single, multiple and fine stranded conductors with plastic or rubber insulation Adapts automatically to the respective cable cross-section; prevents damage to the conductor Cutting depth can be adjusted for different insulation materials With wire cutter for copper and aluminium wires, multiple stranded up to 10 mm² and single stranded up to 6 mm² Smoothly operating mechanism Stripping blades and clamping jaws easily replaceable Low weight Body: plastic, fibreglass-reinforced Blade: special tool steel, oil-hardened For thin ribbon cables up to 10.0 mm width in a single pass Mode of operation of straight cutters An incision is made in the red area only. Not suitable for highly-flexible or armoured insulation materials or for multi-layered insulation. Article No. 12 40 200 EAN 4003773026662 Stripping capacities in square millimetres mm² 0,03 - 10,0 Length stop mm 3,0 - 18,0 Nominal size 200 mm AWG 32 - 7 Length mm 200 Net weight g 202 12 40 200: Adjustable length stop Wire cutter for multiple 12 40 200: Precise stranded wire cables up stripping prevents to 10.0 mm² damage to the conductor technical change and errors excepted Spare Parts Article No. EAN 12 49 01 4003773026679 1 pair of spare blades for 12 40 200 12 49 02 4003773026686 1 pair of spare clamping jaws for 12 40 200 12 49 03 4003773026693 Spare length stop for 12 40 200 12 49 04 4003773053071 Torsion spring for 12 40/50 200 12 49 05 4003773053088 Coil spring in the head for 12 40/50 200 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
12 40 200 价格&库存
很抱歉,暂时无法提供与“12 40 200”相匹配的价格&库存,您可以联系我们找货
