12 52 195
12 52 195
    KNIPEX(凯尼派克)
    KNIPEX - 12 52 195 - Stripper, Automatic Insulation, 28-5AWG, 195 mm
12 52 195 数据手册
Product information 12 52 195 Properly stripped away: with deft precision, strip everything from very fine to thick cables with stranded or solid conductors KNIPEX PreciStrip16 ● Simple, precise stripping of fine wires and solid round cables with a wide capacity range from 0.08 to 16 mm² with only one pair of pliers ● Good grip provided by semi-circular grooved metal holding clamps and exact cut from parabolic stripping blade ● Fine adjustable zero correction of the blade setting to special material requirements, e.g. due to large temperature differences Automatic Insulation Stripper ● With cable cutter for stranded wire from 0.08 to 16 mm² ● With tether attachment point, suitable for KNIPEX Tethered Tools accessories ● Inscription area for customisation ● With adjustable length stop for precision work repeated accurately each time ● Comfortable operation with ergonomic dual-component handle ● Easily replaceable blade cassette General Article No. 12 52 195 EAN 4003773085829 weight 200 g Dimensions 195 mm Technische Attribute Stripping capacities in square millimetres 0.08 — 16.0 mm² AWG 28 — 5 Classification eCl@ss 5.1.4 21040302 ETIM 5.0 EC000163 ETIM 6.0 EC000163 proficl@ss 6.0 AAA002c003 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 4 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 4 Semi-circular grooved holding clamp for better grip that holds practically any insulation material securely in place KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 3 4 With cable cutter on the top side for up to 16 mm² KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 4 4
12 52 195 价格&库存
很抱歉,暂时无法提供与“12 52 195”相匹配的价格&库存,您可以联系我们找货
