36 22 125
36 22 125
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 4.92"(125.0mm)
36 22 125 数据手册
36 22 125 Electronics Mounting Pliers ● ● ● ● ● ● ● ● ● Article No. 36 22 125 EAN 4003773046967 Head mirror polished Handles with multi-component grips Cutting capacities soft wire (diameter) Ø mm 1,2 T1 mm 7,5 T2 mm 2,6 W mm 11,5 W1 mm 7,5 W4 mm 7,5 L3 mm 18,0 Applications cut at 1.6 mm and bend wire Length mm 125 Net weight g 94 Precision pliers for very fine assembly and repair work in electronics For bending and cutting off wire ends on components Sturdy, zero backlash box joint Smooth ground gripping surfaces Edges carefully deburred Low-friction double spring for gentle and even opening The mirror polish together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools High-grade special tool steel, forged, oil-hardened To bend and cut wire at 1.6 mm length below the board technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
36 22 125 价格&库存
很抱歉,暂时无法提供与“36 22 125”相匹配的价格&库存,您可以联系我们找货
