49 41 A21
49 41 A21
    KNIPEX(凯尼派克)
    KNIPEX - 49 41 A21 - Plier, Circlip, 60 mm Jaw Opening Max, 165 mm, Grey Atramentised
49 41 A21 数据手册
Product information 49 41 A21 ● Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips ● With inserted tips for reliable work ● ● ● ● ● ● ● ● ● Heavy duty under continuous use; up to 10 times longer service life Precise, smoothly-operating screw joint Forged Large contact faces on the tips: no distortion of circlips, easy fitting Slim head style allows use in confined areas Internal opening spring, protected and captive Handles with non-slip plastic coating DIN 5254 B; 90° angled tips With overstretching limiter for standardized assembly in accordance with DIN 471 ● The adjustable stop screw prevents the rings from overstretching ● Inserted tips: spring steel wire, drawn ● Pliers body: chrome vanadium electric steel, forged, oil-hardened Precision Circlip Pliers For external circlips on shafts DIN 5254 B General Article No. 49 41 A21 EAN 4003773079613 Pliers grey atramentized Handles with non-slip plastic coating weight 169 g Dimensions 165 x 71 x 13 mm Standard DIN 5254 B Technische Attribute Size of shaft Ø 19 – 60 mm Style 4 Tips (diameter) 1.8 mm Classification eCl@ss 5.1.4 21040301 ETIM 5.0 EC002228 ETIM 6.0 EC002228 proficl@ss 6.0 AAC470c002 UNSPSC 13.1 27112140 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 2 Spring inside the joint: the spring is protected inside the precisely bolted joint. It does not hinder work and cannot get dirty or lost. KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 2
49 41 A21 价格&库存
很抱歉,暂时无法提供与“49 41 A21”相匹配的价格&库存,您可以联系我们找货
