77 02 115
77 02 115
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 4.50"(114.3mm)
77 02 115 数据手册
77 02 115 Electronics Diagonal Cutter ● ● ● ● ● ● ● ● ● ● Article No. 77 02 115 EAN 4003773039334 Head mirror polished Handles with multi-component grips Style 0 Cutting capacities medium hard wire (diameter) Ø mm 1,2 For fine cutting work, e.g. in electronics and fine mechanics Load-optimised for a more direct feel when working Sturdy, zero-backlash box joint Low-friction double spring for gentle and even opening The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutters additionally laser hardened, cutter hardness at least 60 HRC Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger Ball bearing chrome steel Round head, with small bevel Cutting edge hardness approx. 60 HRC Cutting capacities hard 0,6 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 0,3 - 1,6 D mm 7,0 B mm 13,0 A mm 11,0 Nominal size 115 mm Length mm 115 Net weight g 80 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
77 02 115 价格&库存
很抱歉,暂时无法提供与“77 02 115”相匹配的价格&库存,您可以联系我们找货
