78 03 125 ESD
78 03 125 ESD
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 锥形,轻型 凹槽 5.00"(127.0mm)
78 03 125 ESD 数据手册
78 03 125 ESD Electronic Super Knips® ESD ● ● ● ● ● ● ● ● ● ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Electrically discharging handles - dissipative Ground, very sharp cutting edges without bevel Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life Precision shaped tips cut wires resting on a board from 0.2 mm dia. Joint with stainless steel rivet Extremely smooth movement for minimum operator fatigue With opening spring and opening limiter Cutting edge hardness approx. 54 HRC INOX - tool steel ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 78 03 125 ESD EAN 4003773025146 Head polished Handles with multi-component grips Style 0 Pliers Cutting capacities medium hard wire (diameter) Ø mm 1,0 Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,6 D mm 7,5 B mm 9,0 A mm 13,5 Length mm 125 Net weight g 55 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
78 03 125 ESD 价格&库存
很抱歉,暂时无法提供与“78 03 125 ESD”相匹配的价格&库存,您可以联系我们找货
