95 02 21
95 02 21
    KNIPEX(凯尼派克)
    KNIPEX - 95 02 21 - Cable Management Tool, Vinyl Cable Duct Shears, Cuts Up to 4mm Thickness - Cable...
95 02 21 数据手册
95 02 21 Vinyl Shears also for cable ducts ● ● ● ● ● Article No. 95 02 21 EAN 4003773052128 Tool burnished Handles with multi-component grips Cutting capacities mm max. 4.0 Blade length mm 110 Length mm 275 Net weight g 665 For cutting and shortening cable ducts, also for plastic material up to 4.0 mm thickness Special lever transmission Very effective blade geometry Tool body: high-grade chrome vanadium electric steel, oil-hardened Blade: special tool steel, oil-hardened 95 02 21: blade length 110 mm for cutting wide cable ducts; also for plastic material up to 4 mm thickness technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 02 21 价格&库存
很抱歉,暂时无法提供与“95 02 21”相匹配的价格&库存,您可以联系我们找货
