95 31 250
95 31 250
    KNIPEX(凯尼派克)
    KNIPEX - 95 31 250 - Cable Cutter, 32mm Capacity, Aluminium & Copper Cables, 250mm Length
95 31 250 数据手册
95 31 250 Cable Cutter (ratchet action) ● ● ● ● ● ● ● ● ● ● ● Article No. 95 31 250 EAN 4003773043935 Tool black lacquered Handles with multi-component grips For cutting copper and aluminium single conductors as well as multiple stranded cables Not suitable for steel wire and wire ropes Precision ground, hardened blades Clean and smooth cut without crushing and deformation One-hand operation using ratchet principle Little handforce required due to very high transmission ratio Two-stage ratchet drive for easy cutting Simple handling as a result of low weight and compact design - can be used even in confined areas Guard prevents operators’ fingers being pinched High-grade special tool steel, forged, oil-hardened Fixed handle with support area for putting down the pliers when cutting 95 31 250/280: fixed handle with support area as an aid to position the cutters on a flat surface Cutting capacity copper cable, multiple32 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 240 stranded mm² MCM 500 Length mm 250 Net weight g 676 95 31 280: Large cutting capacity: maximum 52 mm dia. / 380 mm² Ratchet principle and two-stage ratchet drive for easier cutting technical change and errors excepted Spare Parts Article No. EAN 95 39 03 4003773039129 Movable handle (3) for 95 31 250/280 95 39 04 280 4003773032472 Feed pawl 95 39 05 4003773039174 Catch (5) for 95 31 250/280 95 39 06 4003773039181 Torsion spring (6) for 95 31 250/280 95 39 07 4003773039198 Pressure spring (7) for 95 31 250/280 95 39 08 4003773039204 Barrel spring for 95 31 250/280 95 39 09 4003773039228 Set of catches (9) for 95 31 250/280 95 39 10 97 N 4003773032441 Cover plate neutral KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 95 39 11 4003773039259 Joint axis (11) for 95 31 250/280 95 39 12 97 4003773032458 Set of distance bolts 3-piece 95 39 13 97 4003773032465 Set of lock nuts 95 39 250 4003773022244 Movable spare blade for 95 31 250 / 95 36 250 ratchet action KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
95 31 250 价格&库存
很抱歉,暂时无法提供与“95 31 250”相匹配的价格&库存,您可以联系我们找货
