95 32 038
95 32 038
    KNIPEX(凯尼派克)
    KNIPEX - 95 32 038 - Cable Cutter, Shear, Ratchet, Telescopic Handle, 38 mm Max Capacity, 560 mm Ove...
95 32 038 数据手册
95 32 038 Cable Shears (ratchet action) with telescopic handles ● ● ● ● ● ● ● ● ● ● Cable shears with adjustable telescopic handles allowing angular positioning For cable diameters up to 38 mm, handles can be positioned at an angle to set the optimum handle width, which makes the shear also suitable for work in confined areas Comfortable work thanks to ratchet action and low weight Heavy duty telescopic handles made of oval aluminium tubing; extendable up to 770 mm for maximum leverage on large cable diameters; retractable down to 570 mm for minimum space requirements during transport Replaceable cutting head Extensive cutting range up to max. Ø 38 mm or max. 280 mm² (e.g. 4 x 70 mm² NYY) in copper and aluminium cables Easier, neater cut due to optimised cutting-edge geometry Adjustable bolted joint Cutting head: special quality high-grade tool steel, oil-hardened Handles: high-strength oval aluminium tubing Handles adjustable in length and angular position for easier work: set the handle length to the optimum lever for powerful cutting; put the handles at an angle for a comfortable gripping position Article No. 95 32 038 EAN 4003773071556 Head burnished Handles with multi-component grips Cutting capacity copper cable, multiple38 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 280 stranded mm² MCM 550 Length mm 570 Net weight g 1980 Setting of a favourable handle width technical change and errors excepted after the first partial cut, the handles open by ratchet action Repeat cutting and opening actions until the cable is cut through Spare Parts Article No. EAN 95 39 038 4003773073260 Spare cutter head for 95 32 038 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 32 038 价格&库存
很抱歉,暂时无法提供与“95 32 038”相匹配的价格&库存,您可以联系我们找货
