95 32 320
95 32 320
    KNIPEX(凯尼派克)
    KNIPEX - 95 32 320 - Cable Cutter, 60mm Capacity, Ratchet Drive, Multi-Component Grips, 320mm Length
95 32 320 数据手册
95 32 320 Cable Cutter (ratchet principle, 3-stage) ● ● ● ● ● ● ● ● ● ● Sturdy. Easy to use. Stable. Innovative ratchet-drive. For cable up to 60 mm diameter. Easy handling due to low weight (825 g) and compact construction (320 mm length) - also usable in confined areas Cutting through copper and aluminium cables with diameters of up to 60 mm in one-hand and two-hand operation Hardened cutting edges, precisely ground, cut smoothly and neatly without crushing For cutting copper and aluminium single conductors as well as multiple stranded cables (not suitable for steel wire and wire ropes) Innovative three-stage ratchet-drive with high leverage for easy cutting in one-hand and two-hand operation Fixed handle with support area for putting down the pliers when cutting High-grade special tool steel, forged, oil-hardened The innovative three gear drive permits three operating modes Fast working with full lift of handles and one-handed operation when cutting through insulation material Powerfully sliding the sickle knife forward when cutting through the stranded conductor with two hand through use of the central lifting area (handling opening of between 1/3 and 2/3) Powerfully pushing the sickle knife forward with one hand to cut through the stranded conductor through use of the first third of the handle lift with one or two hands First manual ratchet-action cable cutter for one-hand and two-hand operation for cutting copper and aluminium cables with diameters of up to 60 mm! Article No. 95 32 320 EAN 4003773075172 Tool black atramentized Handles with multi-component grips Head polished Cutting capacity copper cable, multiple60 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 600 stranded mm² MCM 1200 Length mm 320 Length mm 320 Net weight g 825 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Spare Parts Article No. EAN 95 39 320 01 4003773075714 Pivot cutter repair kit for 95 32 320 and 95 36 320 95 39 320 02 4003773075721 Fixed cutter repair kit for 95 32 320 and 95 36 320 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
95 32 320 价格&库存
很抱歉,暂时无法提供与“95 32 320”相匹配的价格&库存,您可以联系我们找货
