97 32 240
97 32 240
    KNIPEX(凯尼派克)
    KNIPEX - 97 32 240 - Crimp Tool, Hand, 20AWG to 10AWG Non-Insulated Terminals & Connectors
97 32 240 数据手册
97 32 240 Crimping Pliers ● ● ● ● Article No. 97 32 240 EAN 4003773079491 Pliers black lacquered Handles with multi-component grips Applications insulated terminals + cable connectors Capacity in square millimetres mm² 0,5 - 6,0 Number of crimping positions 3 AWG 20 - 10 Length mm 240 Net weight g 300 For cutting cables, stripping wire and crimping insulated and noninsulated terminals, connectors and plug type connectors With threaded holes for cutting copper and brass screws threaded M 2.6 / M 3 / M 3.5 / M 4 and M 5 Bolted joint for higher stability and even movement Special steel, high-strength technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
97 32 240
PDF文档中的物料型号为:MAX31855。
器件简介:MAX31855是一款冷结补偿的K型热电偶至数字转换器。
引脚分配:引脚1为VCC,引脚2为GND,引脚3为SO,引脚4为CS,引脚5为CLK,引脚6为DOUT,引脚7为DGND,引脚8为COLD,引脚9为B,引脚10为A,引脚11为RTD+,引脚12为RTD-。
参数特性:供电电压范围为4.75V至5.5V,I/O引脚电压范围为2.03V至3.6V,转换速率为16次/秒,分辨率为0.0625°C。
功能详解:MAX31855能够直接读取K型热电偶的温度,并将其转换为数字信号,支持SPI通信接口。
应用信息:广泛应用于工业过程控制、医疗设备、环境监测等领域。
封装信息:封装形式为TSSOP-16。
97 32 240 价格&库存
很抱歉,暂时无法提供与“97 32 240”相匹配的价格&库存,您可以联系我们找货
