00 21 19 LB WK
00 21 19 LB WK
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 19 LB WK - Tool Card, ABS, 55 mm Height, 375 mm Width, 310 mm Depth
00 21 19 LB WK 数据手册
00 21 19 LB WK Tool Card empty for L-BOXX® ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Article No. 00 21 19 LB WK EAN 4003773081609 Dimension exterior (interior) width mm mm 375 (-) Dimension exterior (interior) height mm mm 55 (-) Dimension exterior (interior) depth mm mm 310 (-) Net weight g 935 Strong box made of impact- and shock-proof ABS plastic Splash-proof Several boxes can be securely joined together Flexible inner partitions Handle can be lowered into a hollow in the lid to save space Ergonomically shaped handles with additional moulded recess on the side for flexible, convenient handling With two-part tool holder made of hard-wearing polyester fabric Tool holders are connected to each other using hook-and-loop Top section with 10 pockets and 10 elastic straps Upper part of bottom section with 7 pockets and strap for hanging up the tool holder; can also be used to lift or lay the L-BOXX® down Underneath of bottom section with 7 pockets and 7 elastic straps Load-bearing capacity up to 25 kg Two-part tool holder made of hard-wearing polyester fabric Tool holders are connected to each other using hook-and-loop Top tool holder (lid section) with 10 pockets and 10 elastic straps The upper tool holder is screwed to the lid of the L-BOXX® Lower tool holder (bottom section) with 7 pockets and a strap for hanging up the tool holder on the top; can also be used to lift or place in the L-BOXX® Underneath of bottom section with 7 pockets and 7 elastic straps Lower tool holder can be removed from the L-BOXX® if necessary Dimensions (W x H x D): 375 x 55 x 310 mm technical change and errors excepted L-BOXX® is a registered trademark of Sortimo International GmbH KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 19 LB WK 价格&库存
很抱歉,暂时无法提供与“00 21 19 LB WK”相匹配的价格&库存,您可以联系我们找货
