00 21 35 LE
00 21 35 LE
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 35 LE - Tool Case, Robust, Impact Resistant PP, 190 mm Height, 470 mm Width, 370 mm D...
00 21 35 LE 数据手册
00 21 35 LE Tool Case "Robust23" empty ● ● ● ● ● ● ● ● Article No. 00 21 35 LE EAN 4003773077596 Dimension exterior (interior) width mm mm 470 (437) Dimension exterior (interior) height mm mm 190 (172) Dimension exterior (interior) depth mm mm 370 (307) Net weight g 4800 Fit to fly case, made from impact-resistant polypropylene Dustproof and watertight Air pressure compensation valve Temperatures ranging from - 30°C to + 80° C Padlock eyelets Document compartment; tool panels with 35 pouches which can be filled with tools 2 aluminium dividers to customize the bottom tray 30 kg maximum load technical change and errors excepted Con-Pearl® is a registered trade mark of friedola TECH GmbH KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 35 LE 价格&库存
很抱歉,暂时无法提供与“00 21 35 LE”相匹配的价格&库存,您可以联系我们找货
