00 21 36
00 21 36
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 36 - Tool Kit, Electrical, ROBUST34 Series, 26 Piece
00 21 36 数据手册
00 21 36 Tool Case "Robust34" Electric 26 parts ● ● ● ● ● ● ● ● ● ● ● Article No. 00 21 36 EAN 4003773082583 Dimension exterior (interior) width mm mm 510 (480) Dimension exterior (interior) height mm mm 215 (199) Dimension exterior (interior) depth mm mm 419 (356) Net weight g 10000 Fit to fly case, made from impact-resistant polypropylene Dustproof and watertight Air pressure compensation valve Temperatures ranging from - 30°C to + 80° C Padlock eyelets Document compartment; tool boards with 42 tool pockets and 67 straps Lockable base tray can be individually divided using aluminium separator system Ergonomic dual-component handle Volume: 34 l Load-bearing capacity up to 25 kg Equipped with 26 brand name tools; some VDE tested in accordance with DIN EN/IEC 60900 With pressure valve for venting and name plate Aluminium separators for individually dividing up the base tray With document compartment technical change and errors excepted Content 00 21 36 (11) Article No. Quantity Nominal size 00 11 01 Knipex KNIPEX TwinKey®, for all standard cabinets and shut-off systems 08 26 145 Knipex Needle-Nose Combination Pliers 1 12 40 200 Knipex Self-Adjusting Insulation Stripper 1 13 86 200 Knipex Pliers for Electrical Installation 1 16 95 01 SB Knipex KNIPEX ErgoStrip , Universal Stripping Tool 1 70 06 160 Knipex Diagonal Cutter 1 160 mm Knipex KNIPEX Cobra®, Hightech Water 1 Pump Pliers 180 mm 97 53 04 Knipex Self-Adjusting Crimping Pliers for End Sleeves (ferrules), with lateral access 1 98 52 Knipex Cable Knife 1 003484 Wera Kraftform Kompact VDE 16 Slim 1 16135 Stabila Model 70 Electric spirit level 1 87 01 180 ® 1 200 mm 185 mm 430 mm KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 36 价格&库存
很抱歉,暂时无法提供与“00 21 36”相匹配的价格&库存,您可以联系我们找货
