02 02 200
02 02 200
    KNIPEX(凯尼派克)
    KNIPEX - 02 02 200 - 200mm Length High Leverage Combination Plier with 25mm² Capacity
02 02 200 数据手册
02 02 High Leverage Combination Pliers DIN ISO 5746 02 01 180 02 02 180 왘 for heaviest duty 왘 35% saving in power due to new, improved lever action 왘 with gripping zones for flat and round material, suitable for versatile use 왘 with cutting edges for soft, hard and piano wire 왘 long cutting edges for thicker cables 왘 cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC 왘 high grade special tool steel, oil-hardened and tempered KNIPEX High Leverage Combination Pliers with optimum position of the joint facilitate cutting as well as powerful gripping, bending and pulling. Requires 35 % less effort Cutting a hard wire of 2.0 mm dia. with a High Leverage Combination Plier of 180 mm length requires a handforce of only 318 N (31.8 kp) instead of 486 N (48.6 kp) with a common Combination Plier of same length. 02 05 180 02 06 200 02 07 225 Induction hardened cutting edges also suitable for piano wire Gripping zone for round material Article-No. 9 EANLength mm 02 01 180 200 225 02 02 180 200 225 02 05 180 200 225 02 06 180 200 225 02 07 200 225 14 9 Head 9 Handles 9 Cutting capacities  Code 4003773- 013174 013181 013198 034896 034902 043379 043072 043089 010005 010012 010029 010036 022299 022305 polished plastic coated polished with two-colour dual component handles chrome plated with two-colour dual component handles chrome plated insulated with two-colour dual component handles VDE-tested plastic dipped insulated VDE-tested chrome plated ø mm 2.5 2.8 3.0 2.5 2.8 3.0 2.5 2.8 3.0 2.5 2.8 3.0 2.8 3.0 ø mm 2.0 2.2 2.5 2.0 2.2 2.5 2.0 2.2 2.5 2.0 2.2 2.5 2.2 2.5 ø mm mm2 11.5 16.0 13.0 25.0 14.0 25.0 11.5 16.0 13.0 25.0 14.0 25.0 11.5 16.0 13.0 25.0 14.0 25.0 11.5 16.0 13.0 25.0 14.0 25.0 13.0 25.0 14.0 25.0 g 205 280 360 235 330 400 235 330 400 240 335 405 385 490 Powerful gripping, pulling and bending thanks to high leverage
02 02 200 价格&库存
很抱歉,暂时无法提供与“02 02 200”相匹配的价格&库存,您可以联系我们找货
