11 82 130
11 82 130
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 18 ~ 32 AWG
11 82 130 数据手册
11 82 130 Electronics Wire Stripping Shears ● ● ● ● ● Article No. 11 82 130 EAN 4003773071648 Head polished Handles with multi-component grips Stripping capacities in square millimetres mm² 0,01-0,75 Stripping capacities (diameter) Ø mm 0,03-1,0 Length mm 140 Net weight g 75 For cutting and stripping solid, multicore and finely stranded conductors with conductor cross-section up to 0.75 mm² Pointed head of shears above the wire stripping hole for the accurate cutting of fine wire in confined places Easy adjustment to the required diameter of solid or stranded wire with knurled screw and lock nut With opening spring Special tool steel, oil-hardened technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
11 82 130 价格&库存
很抱歉,暂时无法提供与“11 82 130”相匹配的价格&库存,您可以联系我们找货
