49 31 A1
49 31 A1
    KNIPEX(凯尼派克)
    KNIPEX - 49 31 A1 - Plier, Circlip, 25 mm Jaw Opening Max, 140 mm, Grey Atramentised
49 31 A1 数据手册
Product information 49 31 A1 ● Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips ● With inserted tips for reliable work ● ● ● ● ● ● ● Precision Circlip Pliers For external circlips on shafts With overstretching limiter DIN 5254 A ● ● ● ● ● Large contact faces on the tips: no distortion of circlips, easy fitting Bolted joint: precise, zero backlash operation of pliers Internal opening spring, protected and captive Non-slip plastic coating on the handles With overexpansion guard (adjustable using end stop) Adjustment using hexagonal screw Ideal for series production as excessive expansion of rings is effectively prevented DIN 5254 A; straight tips With overstretching limiter for standardized assembly in accordance with DIN 471 The adjustable stop screw prevents the rings from overstretching Inserted tips: spring steel wire, drawn Pliers body: chrome vanadium electric steel, forged, oil-hardened General Article No. 49 31 A1 EAN 4003773073895 Pliers grey atramentized Handles with non-slip plastic coating weight 100 g Dimensions 140 x 64 x 11 mm Standard DIN 5254 A Technische Attribute Size of shaft Ø 10 – 25 mm Style 3 Tips (diameter) 1.3 mm Classification eCl@ss 5.1.4 21040301 ETIM 5.0 EC002228 ETIM 6.0 EC002228 proficl@ss 6.0 AAC470c002 UNSPSC 13.1 27112140 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 2 Spring inside the joint: the spring is protected inside the precisely bolted joint. It does not hinder work and cannot get dirty or lost. KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 2
49 31 A1 价格&库存
很抱歉,暂时无法提供与“49 31 A1”相匹配的价格&库存,您可以联系我们找货
