70 01 160
70 01 160
    KNIPEX(凯尼派克)
    KNIPEX - 70 01 160 - WIRE CUTTER, DIAGONAL, 4MM, 160MM
70 01 160 数据手册
70 01 160 Diagonal Cutter ● ● ● ● ● ● ● Article No. 70 01 160 EAN 4003773013426 Head polished Handles plastic coated Style 0 Pliers black atramentized Cutting capacities medium hard wire (diameter) Ø mm 3,0 The indispensable diagonal cutter for all-round use High-quality material and precise workmanship for long service life Precision cutting edges for soft and hard wire Clean cutting of thin copper wires, also at the cutting-edge tips Cutting edges additionally induction hardened, cutting edge hardness approx. 62 HRC Narrow head style for use in confined areas Vanadium electric steel, forged, multi stage oil-hardened Cutting capacities hard 2,0 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 4,0 Length mm 160 Net weight g 171 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
70 01 160 价格&库存
很抱歉,暂时无法提供与“70 01 160”相匹配的价格&库存,您可以联系我们找货
