74 02 160
74 02 160
    KNIPEX(凯尼派克)
    n/a
74 02 160 数据手册
74 02 160 High Leverage Diagonal Cutter ● ● ● ● For very tough, continuous use High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction hardened (cutting edge hardness approx. 64 HRC), for all sorts of wire including piano wire Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 02 160 EAN 4003773023081 Pliers black atramentized Head polished Handles with multi-component grips Style 0 Cutting capacities medium hard wire (diameter) Ø mm 3,4 Cutting capacities hard 2,5 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,0 Length mm 160 Net weight g 209 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 02 160 价格&库存
很抱歉,暂时无法提供与“74 02 160”相匹配的价格&库存,您可以联系我们找货
