78 31 125
78 31 125
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 凹槽 5.00"(127.0mm)
78 31 125 数据手册
Product information 78 31 125 ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics ● Ground, very sharp cutting edges without bevel ● Precision shaped tips cut wires flush to a surface from Ø 0.2 mm. ● Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life ● Joint with stainless steel rivet ● Extremely smooth movement for minimum operator fatigue ● With opening spring and opening limiter ● With narrow head ● Cutting edges additionally induction-hardened, cutting edge hardness approx. 60 HRC ● Special tool steel, burnished Electronic Super Knips® DIN ISO 9654 General Article No. 78 31 125 EAN 4003773039778 Pliers burnished Head burnished Handles with multi-component grips weight 55 g Dimensions 125 x 71 x 48 mm Standard DIN ISO 9654 Technische Attribute Style 3 Cutting capacities soft wire (diameter) Ø 0.2 – 1 mm 9 mm 7.5 mm Head width 12.5 mm Classification eCl@ss 5.1.4 21040302 ETIM 5.0 EC000165 ETIM 6.0 EC000165 proficl@ss 6.0 AAA949c004 UNSPSC 13.1 27112149 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 1
78 31 125 价格&库存
很抱歉,暂时无法提供与“78 31 125”相匹配的价格&库存,您可以联系我们找货
