87 02 250
87 02 250
    KNIPEX(凯尼派克)
    KNIPEX - 87 02 250 - 250mm Adjustable Water Pump Pliers with Two Colour Dual Component Handles
87 02 250 数据手册
87 02 250 KNIPEX Cobra® Hightech Water Pump Pliers ● ● ● ● ● ● ● ● ● Push the button for adjustment on the workpiece Fine adjustment for optimum adaptation to different sizes of workpieces and a comfortable handle width Self-locking on pipes and nuts: no slipping on the workpiece and low handforce required Gripping surfaces with special hardened teeth, teeth hardness approx. 61 HRC: high wear resistance and stable gripping Box-joint design for high stability due to double guide Reliable catching of the hinge bolt: no unintentional shifting Guard prevents operators’ fingers being pinched Chrome vanadium electric steel, forged, multi stage oil-hardened With slim multi-component grips without collar for better handling and easier transport KNIPEX Cobra® - the Hightech Water Pump Pliers. No more time-consuming presetting of the required opening size. Just position the upper jaw to the workpiece, push button and move close the lower jaw, ingeniously simple. Article No. 87 02 250 EAN 4003773040316 Pliers grey atramentized Head polished Handles with slim multicomponent grips Adjustment positions 25 Capacity for pipes, inches (diameter) Ø Inch 2 Capacities for pipes (diameter) Ø mm 50 Fine adjustment by pushing a button: fast and comfortable. Fast and firm adjustment directly on the workpiece Capacities for nuts mm 46 Length mm 250 Net weight g 366 technical change and errors excepted Teeth set against the direction of rotation have a self-locking effect and prevent slipping on the workpiece. KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Spare Parts Article No. EAN 87 09 01 4003773074724 Assortment of spare parts for adjustment for 86/87 250/300 (without 87 2) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
87 02 250 价格&库存
很抱歉,暂时无法提供与“87 02 250”相匹配的价格&库存,您可以联系我们找货
