87 51 250
    KNIPEX(凯尼派克)
    KNIPEX - 87 51 250 - 250mm Length Cobra ES Extra Slim Water Pump Plier with 34mm Capacity
87 51 250 数据手册
87 51 250 KNIPEX Cobra® ES Water Pump Pliers extra-slim ● ● ● ● ● ● ● ● ● ● ● ● Ideal for service, maintenance and equipment repair, in automotive and general industry Long, narrow jaws Particularly good access to the workpiece due to very slim construction of head and joint area Firm grip also on flat material due to three-point rest Push the button for adjustment on the workpiece Fine adjustment for optimum adaptation to different sizes of workpieces and a comfortable handle width Self-locking on pipes and nuts: no slipping on the workpiece and low handforce required Box-joint design for high stability due to double guide Reliable catching of the hinge bolt: no unintentional shifting Favourable lever action: optimum transmission of force Guard prevents operators’ fingers being pinched Chrome vanadium electric steel, forged, multi stage oil-hardened Due to the increasing compactness of components and machines the workspace becomes more confined. However, the requirements on the gripping force and capacity of the tools do not decrease on the other hand. KNIPEX-"Cobra" ES allows powerful gripping in confined areas. Article No. 87 51 250 EAN 4003773061267 Pliers grey atramentized Head polished Handles with non-slip plastic coating max. gripping depth mm 42,0 Adjustment positions 19 max. parallel opening width mm 37,0 Capacity for pipes, inches (diameter) Ø Inch 1 1/4 Capacities for pipes (diameter) Ø mm 32 Very slim design in the complete head and joint area (compared to conventional water pump pliers) Optimum access to the workpiece. Ideal for service, maintenance and equipment repair, in automotive and general industry Capacities for nuts mm 34 Length mm 250 Net weight g 328 Grips nuts up to 34 mm (1 5/8") across flats Fine adjustment by pushing a button: fast and comfortable. technical change and errors excepted Spare Parts KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Article No. EAN 87 09 01 4003773074724 Assortment of spare parts for adjustment for 86/87 250/300 (without 87 2) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
87 51 250 价格&库存
很抱歉,暂时无法提供与“87 51 250”相匹配的价格&库存,您可以联系我们找货
