95 05 10 SB
95 05 10 SB
    KNIPEX(凯尼派克)
    KNIPEX - 95 05 10 SB - Scissor, Electrician, Polished, 6 mm Cutting Capacity, 190 mm Overall Length
95 05 10 SB 数据手册
95 05 10 SB Electricians’ Shears ● ● ● ● ● ● ● Article No. 95 05 10 SB EAN 4003773082125 Head polished Handles with multi-component grips, fibreglassreinforced Capacity in square millimetres mm² 6,0 Length mm 190 Net weight g 135 technical change and errors excepted Precisely ground blades with fine serration for a clean, non-slip cut Cutting edge with integrated cable cutter With plastic belt pouch Universal shears for electricians Handles with multi-component grips, fibreglass-reinforced Cutting edges made from stainless steel, hardness of cutting edges 56 HRC With crimp area for end sleeves (ferrules) up to 6.0 mm² No slipping thanks to micro-serration Integrated cable cutter 95 05 10 SB: Fast, easy crimping Safely stored and ready to hand at all times KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 05 10 SB 价格&库存
很抱歉,暂时无法提供与“95 05 10 SB”相匹配的价格&库存,您可以联系我们找货
