95 36 320
95 36 320
    KNIPEX(凯尼派克)
    KNIPEX - 95 36 320 - Cable Cutter, 60mm Capacity, Ratchet-drive, 320mm Length
95 36 320 数据手册
95 36 320 Cable Cutter (ratchet principle, 3-stage) ● ● ● ● ● ● ● ● ● ● Article No. 95 36 320 EAN 4003773075189 Tool black atramentized Handles insulated with multicomponent grips, VDEtested Head polished Insulation standard DIN EN 60900 IEC 60900 Sturdy. Easy to use. Stable. Innovative ratchet-drive. For cable up to 60 mm diameter. Easy handling due to low weight (825 g) and compact construction (320 mm length) - also usable in confined areas Cutting through copper and aluminium cables with diameters of up to 60 mm in one-hand and two-hand operation Hardened cutting edges, precisely ground, cut smoothly and neatly without crushing For cutting copper and aluminium single conductors as well as multiple stranded cables (not suitable for steel wire and wire ropes) Innovative three-stage ratchet-drive with high leverage for easy cutting in one-hand and two-hand operation Fixed handle with support area for putting down the pliers when cutting High-grade special tool steel, forged, oil-hardened Cutting capacity copper cable, multiple60 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 600 stranded mm² MCM 1200 Length mm 320 Length mm 320 Net weight g 830 technical change and errors excepted Spare Parts Article No. EAN 95 39 320 01 4003773075714 Pivot cutter repair kit for 95 32 320 and 95 36 320 95 39 320 02 4003773075721 Fixed cutter repair kit for 95 32 320 and 95 36 320 95 39 320 05 4003773075752 Ratchet handle with bar, short KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 95 39 320 06 4003773075769 Fixed cutter handle 95 39 320 07 4003773075776 Cover plate, neutral KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
95 36 320
物料型号: - 型号:LM393
器件简介: - LM393是一款双路低压比较器,广泛应用于模拟信号处理领域。
引脚分配: - 引脚1:OUT- - 引脚2:- - 引脚3:V+ - 引脚4:- IN- - 引脚5:+ IN+ - 引脚6:DIS - 引脚7:- - 引脚8:OUT+
参数特性: - 供电电压:2.5V~36V - 静态电流:200μA - 比较器失调电压:25mV - 输入失调电流:1μA - 响应时间:10μs
功能详解: - LM393包含两个独立的比较器,每个比较器有两个输入端和一个输出端,可以实现电压比较功能。
应用信息: - 电源电压监测 - 过压和欠压保护 - 模拟信号处理
封装信息: - SOIC封装 - DIP封装
95 36 320 价格&库存
很抱歉,暂时无法提供与“95 36 320”相匹配的价格&库存,您可以联系我们找货
