95 61 190
    KNIPEX(凯尼派克)
    缆线 切割器 圆形 剪 7.50"(190.5mm)
95 61 190 数据手册
95 61 190 Wire Rope Cutter forged ● ● ● ● ● ● With two crimping dies for end caps on Bowden cable sheaths and end ferrules for traction cables Comfortable work thanks to handy, slim design and internal opening spring Bolted joint for precise blade guidance, re-adjustable High leverage for reduced effort Cutting-edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Cuts all wire ropes without splaying, including those that are extremely strong Article No. 95 61 190 EAN 4003773040651 Head polished Handles plastic coated Cutting capacity copper cable, multiple- 10 stranded mm² Cutting capacity copper cable, finestranded (diameter) Ø mm Crimping of the end Crimping of the end ferrule onto the traction caps on the Bowden cable cable sheath Internal opening spring 6,00 Cutting capacities wire 5,0 rope (diameter) Ø mm Cutting capacites iron (diameter) Ø mm 4 Cutting capacities medium hard wire (diameter) Ø mm 4,0 Cutting capacity copper cable, multiple7,0 stranded (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,5 AWG 7 Length mm 190 Net weight g 314 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 61 190 价格&库存
很抱歉,暂时无法提供与“95 61 190”相匹配的价格&库存,您可以联系我们找货
