00 21 37
00 21 37
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 37 - Tool Kit, Electrical, ROBUST45 Series, 63 Piece
00 21 37 数据手册
00 21 37 Tool Case "Robust45" Electric 63 parts with integrated rollers and telescopic handle ● ● ● ● ● ● ● ● ● ● ● ● Article No. 00 21 37 EAN 4003773082606 Dimension exterior (interior) width mm mm 609 (540) Dimension exterior (interior) height mm mm 263 (229) Dimension exterior (interior) depth mm mm 428 (364) Net weight g 15000 Fit to fly case, made from impact-resistant polypropylene Dustproof and watertight Air pressure compensation valve Temperatures ranging from - 30°C to + 80° C Padlock eyelets Document compartment; tool boards with 54 tool pockets and 94 straps Lockable base tray can be individually divided using aluminium separator system Ergonomic dual-component handle With two smooth castors With telescopic handle Volume: 45 l 35 kg maximum load With pressure valve for venting and name plate Aluminium separators for individually dividing up the base tray With document compartment technical change and errors excepted Content 00 21 37 (21) Article No. Quantity Nominal size 00 11 01 Knipex KNIPEX TwinKey®, for all standard cabinets and shut-off systems 08 26 145 Knipex Needle-Nose Combination Pliers 1 12 42 195 Knipex KNIPEX MultiStrip 10, Automatic Insulation Stripper 1 13 86 200 Knipex Pliers for Electrical Installation 1 Knipex KNIPEX ErgoStrip , Universal Stripping Tool 1 26 26 200 Knipex Snipe Nose Side Cutting Pliers, (Stork Beak Pliers) 1 200 mm 70 06 160 Knipex Diagonal Cutter 1 160 mm 74 06 200 Knipex High Leverage Diagonal Cutter 1 200 mm Knipex Pliers Wrench, pliers and a wrench in a single tool 1 180 mm 87 01 180 Knipex KNIPEX Cobra®, Hightech Water 1 Pump Pliers 180 mm 97 53 04 Knipex Self-Adjusting Crimping Pliers for End Sleeves (ferrules), with lateral access 1 98 52 Knipex Cable Knife 1 185 mm Knipex Screwdriver (Slim) for crossrecessed screws, Pozidriv® 1 PZ1 16 95 01 SB 86 03 180 98 25 01 SL ® 1 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 98 20 35 SL Knipex Screwdriver (Slim) for slotted screws 1 3,5 x 100 mm 3003010119 Picard Locksmith’s hammer 1 300 g 004018 Wera 8100 SA 8 Zyklop set of metal ratchets, 28 parts 1 1/4" 003760 Wera Joker open-end wrench 1 10 x 13 mm 18115 Stabila Pocket Electric mini spirit level 1 68 mm 003484 Wera Kraftform Kompact VDE 16 Slim 1 16135 Stabila Model 70 Electric spirit level 1 430 mm 361 252 1 Rennsteig Electrician’s Chisel 1 250 x 10 mm KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
00 21 37 价格&库存
很抱歉,暂时无法提供与“00 21 37”相匹配的价格&库存,您可以联系我们找货
