13 66 180 T
13 66 180 T
    KNIPEX(凯尼派克)
    KNIPEX - 13 66 180 T - Plier, Stripper, 180 mm Length
13 66 180 T 数据手册
13 66 180 T KNIPEX StriX Insulation Stripper with Cable Shears with tether attachment point ● ● ● ● ● ● ● ● Article No. 13 66 180 T EAN 4003773081906 Pliers chrome plated For single, multiple and fine stranded conductors with plastic or rubber insulation up to 5.0 mm dia. or 10 mm² cable cross-section Increments in the jaw provide a visual orientation aid for stripping consistent lengths (11 mm and 16 mm) Easy adjustment to the required diameter of solid or stranded wire with knurled screw and lock nut Shear blade for cutting copper and aluminium cable up to Ø 15 mm (5 x 2.5 mm²) Slim dimensions for easy access Bolted joint: precise, zero backlash operation of pliers High-grade special tool steel, forged, multi stage oil-hardened Pliers with integrated, insulated tether attachment point for a tool tether Head Handles insulated with multicomponent grips, VDEtested with integrated insulated tether attachment point for a tool tether Insulation standard IEC 60900 DIN EN 60900 Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 50 stranded mm² Stripping capacities in square millimetres mm² 10 Stripping capacities (diameter) Ø mm 5 AWG 8 Length mm 180 Net weight g 212 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
13 66 180 T 价格&库存
很抱歉,暂时无法提供与“13 66 180 T”相匹配的价格&库存,您可以联系我们找货
