36 12 130
36 12 130
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 5.25"(133.4mm)
36 12 130 数据手册
36 36 Electronics Mounting Pliers 36 12 130 Model 36 12 130: to bend wire in shape for the distance to the plate 36 22 125 Model 36 22 125: to bend and cut wire at 1.6 mm length below the plate 왘 precision pliers for ultra fine assembly work, e. g. in electronics and fine mechanics 왘 for bending and cutting wire ends 왘 precision box joint 왘 smooth ground gripping surfaces 왘 edges carefully deburred 왘 low-friction double spring for gentle and even opening 왘 the mirror polish together with a fine film of oil offer the best possible rust protection - no circuit faults caused by peeling chrome from plated tools 왘 special tool steel, oil-hardened and tempered W1 T2 Model 36 32 125: to crunch and cut wire at 1.6 mm length below the plate 36 32 125 L3 T1 W T2 L3 Model 36 42 125: to cut wire at 1.3 mm length below the plate 36 42 125 SB Article-No. 9 EANLength mm 9 Head 9 Handles 9 Style to Code 4003773- 36 12 130 016861 36 22 125 046967 36 32 125 016885 36 42 125 SB 016892 mirror polished with two-colour dual component handles bend wire shape cut at 1.6 mm and bend wire cut at 1.6 mm and crunch wire cut wire, distance 1.3 mm T1 W  9 Dimensions L3 mm 23.0 18.0 18.0 18.0 W mm 12.0 11.5 11.5 11.5 T1 mm 7.5 7.5 7.5 7.5 W1 mm 5.5 7.0 7.0 – T2 mm 6.0 2.6 4.0 4.0 mm g – 80 1.2 90 1.0 90 1.2 100 41
36 12 130 价格&库存
很抱歉,暂时无法提供与“36 12 130”相匹配的价格&库存,您可以联系我们找货
