48 41 J21
48 41 J21
    KNIPEX(凯尼派克)
    KNIPEX - 48 41 J21 - Plier, Circlip, 60 mm Jaw Opening Max, 165 mm, Grey Atramentised
48 41 J21 数据手册
Product information 48 41 J21 ● Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips ● With inserted tips for reliable work ● ● ● ● ● Precision Circlip Pliers For internal circlips in bore holes DIN 5256 D ● ● ● ● ● Bolted joint: precise, zero backlash operation of pliers Non-slip plastic coating on the handles With overexpansion guard (adjustable using end stop) Adjustment using hexagonal screw Ideal for series production as excessive expansion of rings is effectively prevented 90° angled tips With overstretching limiter for standardized assembly in accordance with DIN 472 The adjustable stop screw prevents the rings from overstretching Inserted tips: spring steel wire, drawn Pliers body: chrome vanadium electric steel, forged, oil-hardened General Article No. 48 41 J21 EAN 4003773080695 Pliers grey atramentized Handles with non-slip plastic coating weight 175 g Dimensions 165 x 48 x 22 mm Standard DIN 5256 D Technische Attribute Style 4 Size of bore Ø 19 – 60 mm Tips (diameter) Ø 1.8 mm Classification eCl@ss 5.1.4 21040301 ETIM 5.0 EC002228 ETIM 6.0 EC002228 proficl@ss 6.0 AAC470c002 UNSPSC 13.1 27112140 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 1
48 41 J21 价格&库存
很抱歉,暂时无法提供与“48 41 J21”相匹配的价格&库存,您可以联系我们找货
