61 02 200
61 02 200
    KNIPEX(凯尼派克)
    KNIPEX - 61 02 200 - Cutting Nipper, Bolt End, High Lever, 6mm Cutting Capacity, 200 mm Length
61 02 200 数据手册
61 02 200 Bolt End Cutting Nipper high lever transmission ● ● ● ● ● ● ● ● Article No. 61 02 200 EAN 4003773067047 Pliers black atramentized Head polished Handles with slim multicomponent grips Cutting capacities medium hard wire (diameter) Ø mm 4,0 Powerful, compact, comfortable Compared to conventional lever-assisted end cutting nippers, greater cutting capacity, less effort required and better handling For all wire classes including piano wire Exceptional cutting capacity due to high-leverage joint Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Vanadium electric steel, forged, multi stage oil-hardened With slim multi-component grips without collar for better handling and easier transport With large contact surface on the handles for better allotment of pressure and more comfort at work Extraordinary cutting performance: also for piano wire Particularly efficient for fence construction Almost flush cutting of bolts, nails etc. Cutting capacities hard 3,5 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,0 Cutting capacities soft wire (diameter) Ø mm 1,0 - 6,0 Length mm 200 Net weight g 435 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
61 02 200 价格&库存
很抱歉,暂时无法提供与“61 02 200”相匹配的价格&库存,您可以联系我们找货
