71 12 200
71 12 200
    KNIPEX(凯尼派克)
    KNIPEX - 71 12 200 - 200mm CoBolt Lever Action Centre Bolt Cutters with Opening Spring and Stirrup L...
71 12 200 数据手册
71 12 200 KNIPEX CoBolt® Compact Bolt Cutters ● ● ● ● ● ● ● ● ● ● Precision cutting edges for soft and hard wire as well as piano wire Cuts bolts, nails, rivets, etc. up to 5.2 mm dia. Most efficient joint design ensures exceptional cutting performance with little effort Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Improved cutting performance Micro-structured cutting edge allows easy cutting of large crosssections With gripping surface below the joint for gripping and pulling wires with a diameter as from 1.0 mm With slim multi-component grips without collar for better handling and easier transport Opening spring and locking device are integrated in the handles also for comfortable work and protected transport 60 % less effort required compared to conventional high-leverage diagonal cutters The ingenious lever-action mechanism ensures an extremely favourable lever ratio with very little friction. The cutting force over 30 times higher than the hand force applied. Article No. 71 12 200 EAN 4003773066859 Pliers black atramentized Handles with slim multicomponent grips Style 1 Cutting capacities medium hard wire (diameter) Ø mm 5,2 71 01/02/12 200 and 71 31/32 200 Cutting capacities hard 4,0 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,6 Cutting capacities soft wire (diameter) Ø mm 6,0 Length mm 200 Net weight g 375 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
71 12 200 价格&库存
很抱歉,暂时无法提供与“71 12 200”相匹配的价格&库存,您可以联系我们找货
