86 06 250
86 06 250
    KNIPEX(凯尼派克)
    KNIPEX - 86 06 250 - Plier, Water Pump, Insulated, 52 mm Jaw Opening, 250 mm Overall Length
86 06 250 数据手册
86 06 250 Pliers Wrench pliers and a wrench in a single tool ● ● ● ● ● ● ● ● ● ● ● ● Replaces the need for sets of metric and imperial spanners Smooth jaws for damage free installation of plated fittings - working directly on chrome! Adjustable tightening tool Also excellent for gripping, holding, pressing and bending workpieces Push the button for adjustment on the workpiece Zero backlash jaw pressure prevents damage to edges of sensitive components Parallel jaws give a more solid grip; its design allows flexible adjustment of all widths up to the specified maximum size Reliable catching of the hinge bolt: no unintentional shifting The ratchet type principle allows quick and easy tightening and release of all bolted connections Lever transmission greater than 10 : 1 for strong gripping power Chrome vanadium electric steel, forged, oil-hardened With scaling for presetting the width apart from the workpiece The smooth jaws grip all parallel surfaces in the capacity range with a high degree of pressure if necessary and open up almost unlimited application possibilities for the pliers wrench: e.g. for tightening locknuts, exerting pressure to activate the adhesive power of contact adhesives, edge breaking in tile work, snapping cable ties, utilisation as a small vice. Article No. 86 06 250 EAN 4003773082408 Pliers chrome plated Handles insulated with multicomponent grips, VDEtested Insulation standard IEC 60900 DIN EN 60900 B2 mm 8,0 B3 mm 14,0 B1 mm 8,0 Adjustment positions 19 Capacities for nuts Inch 2 Pliers wrench: zero backlash contact pressure, no damage to edges Conventional open end wrench: edge pressure causes surface damage Capacities for nuts mm 52 Length mm 250 Net weight g 515 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
86 06 250 价格&库存
很抱歉,暂时无法提供与“86 06 250”相匹配的价格&库存,您可以联系我们找货
