86 07 250
86 07 250
    KNIPEX(凯尼派克)
    KNIPEX - 86 07 250 - 250mm 1000V VDE Insulated Pliers Wrench
86 07 250 数据手册
86 07 250 Pliers Wrench insulated ● ● ● ● ● ● ● ● ● Article No. 86 07 250 EAN 4003773065067 Pliers chrome plated Handles with dipped insulation, VDE-tested Insulation standard IEC 60900 DIN EN 60900 B2 mm 8 B3 mm 14 B1 mm 8,0 Adjustment positions 17 Capacities for nuts Inch 1 3/4 Pliers and a wrench in a single tool Also excellent for gripping, holding, pressing and bending workpieces Zero backlash jaw pressure prevents damage to edges of sensitive and soft nuts (Cu) With scale for presetting the opening width apart from the workpiece No unintentional shift of the gripping jaws and no slipping of the joint Parallel jaws give a more solid grip; its design allows flexible adjustment of all widths up to the specified maximum size The ratchet type principle allows quick and easy tightening and release of all bolted connections Lever transmission greater than 10 : 1 for strong gripping power Chrome vanadium electric steel, forged, oil-hardened Scale for setting the opening width, apart from the workpiece Capacities for nuts mm 46 Length mm 250 Net weight g 615 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
86 07 250 价格&库存
很抱歉,暂时无法提供与“86 07 250”相匹配的价格&库存,您可以联系我们找货
