35 11 115
35 11 115
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 4.50"(114.3mm)
35 11 115 数据手册
Product information 35 11 115 ● Precision pliers for fine assembly work, e g. in electronics and fine mechanics ● Load-optimised for a more direct feel when working ● For gripping, holding and bending ● Sturdy, zero backlash box joint ● Smooth ground gripping surfaces ● Soft transitions; no sharp edges ● Low-friction double spring for gentle and even opening ● The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools ● Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger ● Flat, wide jaws ● Ball bearing chrome steel Electronics Pliers DIN ISO 9655 General Article No. 35 11 115 EAN 4003773016694 Head mirror polished Handles with non-slip plastic coating weight 62 g Dimensions 115 x 62 x 12 mm Standard DIN ISO 9655 Technische Attribute Style 1 22.5 mm 6.5 mm 2.0 mm 4.0 mm Head width 11.0 mm Classification eCl@ss 5.1.4 21040301 proficl@ss 6.0 EAA840c015 UNSPSC 13.1 27112149 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 2 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 2
35 11 115 价格&库存
很抱歉,暂时无法提供与“35 11 115”相匹配的价格&库存,您可以联系我们找货
