64 62 120 ESD
64 62 120 ESD
    KNIPEX(凯尼派克)
    尖头(倾斜) 切割器 成角度,65° 4.75"(120.7mm)
64 62 120 ESD 数据手册
64 62 120 ESD Electronics End Cutting Nippers ESD ● ● ● ● ● ● ● ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Electrically discharging handles - dissipative Sturdy, zero backlash box joint Low-friction double spring for gentle and even opening The mirror polish together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutting edges additionally induction hardened, cutting edge hardness at least 56 HRC With two-colour dual component grips, black/grey High-grade special tool steel, forged, multi stage oil-hardened Style:Oblique End Cutter, mini-blade with small bevel, α = 65° ❍ ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 64 62 120 ESD EAN 4003773025085 Head mirror polished Handles with multi-component grips Style 6 Cutting capacities soft wire (diameter) Ø mm 0,6 B mm 18,5 D mm 6,0 C mm 5,0 A mm 9,5 Dimensions angle ° 65 Length mm 120 Net weight g 70 64 62 120 ESD 64 62 120 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
64 62 120 ESD 价格&库存
很抱歉,暂时无法提供与“64 62 120 ESD”相匹配的价格&库存,您可以联系我们找货
