70 05 160 T
70 05 160 T
    KNIPEX(凯尼派克)
    KNIPEX - 70 05 160 T - Cutter, Diagonal, 160 mm, 4 mm
70 05 160 T 数据手册
70 05 160 T Diagonal Cutter with tether attachment point ● ● ● ● ● ● ● ● ● Article No. 70 05 160 T EAN 4003773080022 Pliers chrome plated The indispensable diagonal cutter for all-round use High-quality material and precise workmanship for long service life Precision cutting edges for soft and hard wire Clean cutting of thin copper wires, also at the cutting-edge tips Cutting edges additionally induction hardened, cutting edge hardness approx. 62 HRC Narrow head style for use in confined areas Vanadium electric steel, forged, multi stage oil-hardened With elongated cutting edge Pliers with tether attachment point for mounting a fall protection Head Handles with multi-component grips, with integrated tether attachment point for a tool tether Style 0 Cutting capacities medium hard wire (diameter) Ø mm 3,0 Slim head style and precise cut at blade tips: Advantageous when working in confined areas Cutting capacities hard 2,0 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 4,0 Length mm 160 Net weight g 210 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
70 05 160 T 价格&库存
很抱歉,暂时无法提供与“70 05 160 T”相匹配的价格&库存,您可以联系我们找货
