74 06 180
74 06 180
    KNIPEX(凯尼派克)
    KNIPEX - 74 06 180 - Cutter, Side, 180 mm, Diagonal, 3.8 mm, 64 °
74 06 180 数据手册
74 06 180 High Leverage Diagonal Cutter ● ● ● ● ● With integrated forged axle for heaviest duty Suitable for all types of wire including piano wire High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction-hardened, cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 06 180 EAN 4003773022985 Pliers chrome plated Handles insulated with multicomponent grips, VDEtested Style 0 Head Insulation standard IEC 60900 DIN EN 60900 Cutting capacities medium hard wire (diameter) Ø mm 3,8 Cutting capacities hard 2,7 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,2 Length mm 180 Net weight g 280 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 06 180 价格&库存
很抱歉,暂时无法提供与“74 06 180”相匹配的价格&库存,您可以联系我们找货
