81 11 250
81 11 250
    KNIPEX(凯尼派克)
    KNIPEX - 81 11 250 - Plier, Slip Joint, Adjustable, 75 mm, Jaw, 250 mm, Length
81 11 250 数据手册
81 11 250 Siphon- and Connector Pliers for traps, tube fittings and connectors ● ● ● ● ● ● ● ● ● ● Article No. 81 11 250 EAN 4003773078470 Pliers black atramentized Handles with non-slip plastic coating Working Capacity (diameter) Ø mm 10 - 75 Adjustment positions 25 Length mm 250 Net weight g 355 For siphons, oil filters, plastic pipes and connectors up to 80 mm diameter Fine adjustment for ideal adjustment to diverse diameters Robust, heavy duty Ideal for tightening and loosening siphon screw connections, plastic pipe fittings and round union nuts For connectors and couplings with screw connection, such as Cannon circular connectors For gentle loosening of hoses on nozzles and filter cartridges 25 adjustment positions, box-joint design Ergonomic handle geometry Chrome vanadium electric steel, forged, oil-hardened With exchangeable plastic jaws for sensitive surfaces; up to Ø 75 mm technical change and errors excepted Spare Parts Article No. EAN 81 19 250 4003773078500 2 pairs of plastic jaws for 81 11 250 / 81 13 250 for traps, tube fittings and connectors KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
81 11 250 价格&库存
很抱歉,暂时无法提供与“81 11 250”相匹配的价格&库存,您可以联系我们找货
