90 23 01 BK
90 23 01 BK
    KNIPEX(凯尼派克)
    KNIPEX - 90 23 01 BK - Pipe Cutter, Plastic Tube, 202 mm, 50 mm
90 23 01 BK 数据手册
Product information 90 23 01 BK ● Cut and chamfer all common domestic plastic drain pipes up to Ø 50 mm in a single operation ● Reversible high-quality ball-bearing steel blade, can be easily replaced without tools ● Clean cut: no readjusting or deburring required, reducing potential blockages or damages of the seals KNIPEX DP50 Pipe Cutter for plastic drain pipes ● "Cuts high temperature and other plastic pipes with Ø 32, 40 or 50 mm and wall thicknesses up to 2.4 mm" ● Optimal cutting due to slide-bearing and self-adjusting guide rolls ● Easy positioning due to clear view of cutting point ● Spring-loaded blade: no inconvenient readjusting while cutting ● Exchangeable blade with two cutting edges can be reversed when showing signs of wear ● Cuts lengths as small as 10 mm ● Durable housing made of glass fibre reinforced plastic General Article No. 90 23 01 BK EAN 4003773087809 Handles plastic coated Weight 142 g Dimensions 202 x 40 x 19 mm REACH compliant does not contain SVHC RoHS compliant not applicable technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 1 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 2 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 3 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 4 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 5 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 6 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 7 8 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 05.05.2022 | page 8 8
90 23 01 BK 价格&库存
很抱歉,暂时无法提供与“90 23 01 BK”相匹配的价格&库存,您可以联系我们找货
