95 61 150
95 61 150
    KNIPEX(凯尼派克)
    KNIPEX - 95 61 150 - Cable Cutter, Shear, 3 mm Cutting Capacity, 150 mm Overall Length
95 61 150 数据手册
95 61 150 Bowden Cable Cutter ● ● ● ● ● ● ● Article No. 95 61 150 EAN 4003773065197 Shears black atramentized Head polished Handles plastic coated Cutting capacity copper cable, finestranded (diameter) Ø mm 3 For Bowden cables and soft wire rope up to 3.0 mm dia. (also V2A) Smooth and clean cutting due to special shape of the cutting edges Sickle shape cutting edges surround the material and prevent the wire rope fanning out Little handforce required due to very high transmission ratio With opening spring and locking device Cutting edges additionally induction hardened High-grade special tool steel, forged, multi stage oil-hardened Cutting capacities wire 3 rope (diameter) Ø mm Length mm 150 Net weight g 205 technical change and errors excepted Spare Parts Article No. EAN 95 69 190 01 4003773053873 Joint screw, nut and washer for 95 61 190 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 61 150 价格&库存
很抱歉,暂时无法提供与“95 61 150”相匹配的价格&库存,您可以联系我们找货
